Intel Core i7-720QM Processor (for mobile)
miz62
It has 1.6ghz
in turbo it can get to 2.8ghz
i understand it gets to 2.8 with one core
but if all the 4 cores are working it gets only to 1.7ghz
am i right?
Aubrey_W_
You can find the specs and datasheet for this processor here: http://ark.intel.com/Product.aspx?id=43122&code=Intel%c2%ae+Core%e2%84%a2+i7-720QM+Processor+(6M+Cache%2c+1.60+GHz)
Regards.
Aubrey W.
Intel Software Network Support
miz62
The source you gave doesn't tell what happen when all the 4 cores are working
gaston-hillar
Valued Contributor I
Hi Miz62,
A few months ago, I've written a simpleand brief post on Dr Dobb's Go Parallel regarding the microprocessor you mention and Turbo Boost. There is an example in C# with source code thatcan help you.
Measuring Speedup is Challenging with Intel Turbo Boost Technology
Hope it helps.
You can also read another post about the Intel Turbo Boost Technology Monitor. It will also help you to understand what's going on with this amazing technology.
Intel Turbo Boost Technology Monitor: A Windows Gadget to Understand Dynamic Frequencies
Hope it helps.
Cheers
TimP
As Gaston pointed out, the Turbo mode speedup when all cores are active is far less than for a single core, due to thermal limits.
Also frequently of interest is the low efficiency of Turbo mode; the best case I have seen for a large application was a 7% performance increase for a 15% increase in system power consumption with a 10% clock speed boost.
