Intel Quick Assist in Linux
Valli_A_
I need both Compression and Openssl. So I think Intel Quick Assist is more suitable for it. I have used Intel Quick Sync.
For enabling quick sync in Xeon processor E3-1200 v3 , I needed C226 chipset and Intel HD Graphic Card. Similarly, If I need to enable Quick Assist, I need chipset 89xx. In addition to that what are the components I needed actually? Will Intel Quick Assist also work in same setup (Xeon processor E3-1200 v3, Intel HD Graphic Card) having chipset 89xx?
For Intel Quick Sync, I tested initially in my laptop Intel® Core™ i7-5600U CPU @ 2.60GHz × 4
Similarly, Can I be able to test Intel Quick Assist also in my laptop? Will it work?
I am using CentOS 7.2
Will the installation steps in the link http://www.intel.com/content/www/us/en/intelligent-systems/tolapai/ep80579-openssl-apache-linux-appl-note.html work for me in my laptop and also in Xeon processor E3-1200 v3, Intel HD Graphic Card) having chipset 89xx?
Do I need to change any other hardware other than chipset 89xx?
Valli_A_
When I tried to run it in my laptop it is showing
      QAT Devices found: 0 QAT1.6 devices
                        0 QAT1.5 devices
     Configuration:     Build Acceleration and Sample Code
                        No Device detected
                        And SR-IOV Disabled
     Exit and re-enter to set defaults
I followed the instructions in https://01.org/sites/default/files/page/330750-001_qat_gsg.pdf and the downloaded package is qatmux.l.2.6.0-60
But Intel Quick Sync Technology worked in my laptop Intel® Core™ i7-5600U CPU @ 2.60GHz × 4. But Intel Quick Assist is not working in my laptop.
Why so?
