MPI_Abort(MPI_COMM_WORLD, 1)
Pantoja_Clavijo__Jul
We´re trying to compile and run wrf model 3.8.1 with compiler intel parallel studio xe 2016 update3, in rhel Enterprise Server 7.2. The processors are Intel(R) Xeon(R) CPU E5-2690 v3 @ 2.60GHz.
Following this url:
https://software.intel.com/en-us/articles/how-to-get-wrf-running-on-the-intelr-xeon-phitm-coprocessor
All compilation modules ends ok, but when run wrf.exe, it stops with this message:
mpiexec.hydra -np 20 ./wrf.exe
rank 9 in job 11  master_33806   caused collective abort of all ranks
  exit status of rank 9: killed by signal 9
rank 4 in job 11  master_33806   caused collective abort of all ranks
  exit status of rank 4: killed by signal 9
rank 3 in job 11  master_33806   caused collective abort of all ranks
  exit status of rank 3: killed by signal 9
rank 2 in job 11  master_33806   caused collective abort of all ranks
  exit status of rank 2: killed by signal 9
And the file rsl.error.0000 is:
taskid: 0 hostname: master
 module_io_quilt_old.F        2931 F
 MPASPECT: UNABLE TO GENERATE PROCESSOR MESH.  STOPPING.
  PROCMIN_M            1
  PROCMIN_N            1
  P                   -7
  MINM                 1
  MINN                -7
-------------- FATAL CALLED ---------------
FATAL CALLED FROM FILE:  module_dm.b  LINE:     155
module_dm: mpaspect
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
Previously, we test wrf configured with option 20 (dmpar) INTEL (ifort/icc): Xeon (SNB with AVX mods), with same results... (same error in wrf.exe)
Thanks in advance
littlewang
Have you solved the above problems? If so, can you give me some guidance? Thank you
James101
Same problem. Waiting for solution
