MPI_Comm_connect issue
Manhas__Ujwal
Hi ,
i am trying to connect processes running as clients and a server .
I run the server as mpiexec -n 1  -genv I_MPI_FABRICS shm:tcp ./ConsoleApplication1.exe
and the clients as mpiexec -n 2 .\ConsoleApplication2.exe
The code for server is as shown below
int num_errors = 0;
int rank, size,again;
char port_name[MPI_MAX_PORT_NAME] , pname2[MPI_MAX_PORT_NAME];
MPI_Status status;
//MPI_Comm comm1, comm2;
MPI_Comm client;
int data = 0;
double buf[MAX_DATA];
MPI_Init(NULL, NULL);
MPI_Comm_size(MPI_COMM_WORLD, &size);
MPI_Comm_rank(MPI_COMM_WORLD, &rank);
if (rank == 0)
MPI_Open_port(MPI_INFO_NULL, port_name);
while (1) {
MPI_Comm_accept(port_name, MPI_INFO_NULL, 0, MPI_COMM_WORLD,
&client);
again = 1;
while (again) {
MPI_Request rq;
MPI_Recv(buf, MAX_DATA, MPI_DOUBLE,
MPI_ANY_SOURCE, MPI_ANY_TAG, client, &status);
//MPI_Wait(&rq, &status);
switch (status.MPI_TAG) {
case 0: MPI_Comm_free(&client);
MPI_Close_port(port_name);
MPI_Finalize();
return 0;
case 1: MPI_Comm_disconnect(&client);
again = 0;
break;
case 2: printf("value received%lf", buf[0]);
break;
default:
/* Unexpected message type */
MPI_Abort(MPI_COMM_WORLD, 1);
MPI_Finalize();
return 0;
and the code for client ( a test code only ) is as shown below
MPI_Comm server;
char port_name[MPI_MAX_PORT_NAME];
int tag = 2 , n= MAX_DATA;
int rank, size;
MPI_Init(&argc, &argv);
int prov;
//MPI_Init_thread(NULL, NULL, MPI_THREAD_MULTIPLE, &prov);
ifstream ifs("E:/mpi_port_name.txt", ios_base::in);
ifs.getline(port_name, MPI_MAX_PORT_NAME + 1);
ifs.close();
MPI_Comm_connect(port_name, MPI_INFO_NULL, 0, MPI_COMM_SELF,
&server);
////while (!done) {
// tag = 2; /* Action to perform */
// buf[0] = 3.1415926;
// MPI_Send(buf, n, MPI_DOUBLE, 0, tag, server);
// /* etc */
//MPI_Send(buf, 0, MPI_DOUBLE, 0, 1, server);
//MPI_Comm_disconnect(&server);
MPI_Finalize();
return 0;
Now the problem i am facing is that the client code hangs in the MPI_Comm_connect call whereas if i run a single client the connection is established properly.
My problem is i have to connect more than one process of a job with another process dynamically . I am new to MPI so any help will be much appreciated .
Ujwal
TimP
This question would be more likely to get attention on the companion forum on hpc and cluster computing.
