MPI stops stoichastically
Anders_S_1
New Contributor III
Hi
I have used MPI to parallelize my code using ifort and Windows. The code stops stoichastically, mainly at one function call. When I eliminated this call it stops at other positions.
I am not sure if the stop is due to Fortran or to MPI. I have tried to move to OpenMP, but I am not sure if this is possible due to assumed-size arrays.
If this is a known problem with MPI, can I move to ifx+MPI or back to older ifort and/or MPI versions? This is a very severe problem in my case, as the code has to be restarted regularly.
I have used the MPI debugger at the highest level, but I did not find any understandable error code.
Best regards
Anders_S
