My Parallel archiver version 3.46 is here...
aminer10
Hello......
This new version was enhanced more, and here is what i have added:
- Now it supports processor groups on windows, so that it can use more than 64 logical processors and it scales well.
- It's now NUMA-aware and NUMA efficient.
- Now it minimizes efficiently the contention so that it scales well.
And i have added a fourth parameter to the constructor, it is the boolean parameter that is processorgroups to support processor groups on windows , if it is set to true it will enable you to scale beyond 64 logical processors and it will be NUMA efficient.
I have thoroughly tested and stabilized my parallel archiver for many years, and now i think that it is more stable and efficient, so i think you can be more confident with it.
Now when you extract files with ExtractAll() or ExtractFiles() methods using the wrong password, it will report it correctly and  DeleteFiles() method will report the files that do not exist.
Other than that i have tested it thoroughly and i think it is more stable now and its interface is complete.
Notice also that i have not used a global password , but every file can be encrypted with a different password using my Parallel AES encryption with 256 bit keys. So the security level is this:
- When you encrypt , the content of the files will be encrypted but the names of the files and directories will not be encrypted, But if you want to encrypt also the names of the files and directories using Parallel AES encryption with 256 bit keys, please compress first into an archive, and after that encrypt all the archive into another archive.
- But when you encrypt , you can update the files with the update() method without giving the right password, and you can delete the files without giving the right password, but my level of security is that you can not access the encrypted data without giving the right password.
You can download the new updated version 3.46 of my Parallel archiver from:
Thank you,
Amine Moulay Ramdane.
ArthurRatz
Downloaded. Very good parallel application. Thanks. :)
