1705 Discussions
My problem with workqueuing model , please do me a favor
chbq
hi ,I want to parallel do-while codes with the workqueuing modol. soI writen a simple program for testing, however,the following codes does not get the right result as the serial ones,can you tell me why? thank you!
float ParallelTest(float *Array)
int pjn,step;
float sum=0;
pjn=1000;
#pragma intel omp parallel taskq shared(pjn,Array) reduction(+:sum)
do
#pragma intel omp task captureprivate(pjn)
for(step=0;step{
sum+=Array[step]/(10*SIZE*SIZE);
// I add these codes for increasing calculation time
sum=sum*10/10*20/20*30/30;
pjn=pjn/2;
}while(pjn!=1);
return sum;
the serial codes is :
int pjn,step;
float sum=0;
pjn=1000;
do
for(step=0;step{
pjn=pjn/2;
}while(pjn!=1);
return sum;
