1699 Discussions
Not able to connect to the license server for Intel Vtune Performance Analyzer
Anupam_Dev
I am getting this error message. I have the license file and have used it during the installation but still gives the error message.
TimP
You'd be more likely to get help if you would choose a more suitable forum section, such as the one on licensing, and give more detail. For example, are you trying to install a floating license, or a simple local license? What OS; does your license match the OS? Did you actually supply the license file at installation, or attempt to install by entering serial number?
Anupam_Dev
I have tried both the way. I am using windows and it is not a floating license.
