Parallel Quicksort 1.0 ...
aminer10
Hello
Parallel Quicksort using two cores, it is for educational purpose...
It uses my Thread Pool Engine and quicksort two arrays in parallel
and merge them....
Note: On Delphi it gave me 1.7x on two cores - with more optimization,
delphi will give you better scalability...- . Freepascal gave me just 1.2x,
so, FreePascal still have to be optimized on 'some' parts for better parallel
computing...
And please look at pqsort.pas inside the zip file - compile and execute it...
You can download Parallel Quicksort from:
http://pages.videotron.com/aminer/
Language: FPC Pascal v2.2.0+ / Delphi 7+: http://www.freepascal.org/
Operating Systems: Win , Linux and Mac (x86).
Required FPC switches: -O3 -Sd -dFPC -dWin32 -dFreePascal
-Sd for delphi mode....
Required Delphi switches: -DMSWINDOWS -$H+
For Delphi 5,6,7 use -DDelphi
For Delphi 2005,2006,2007,2009,2010+ use the switch -DDELPHI2005+
Sincerely,
Amine Moulay Ramdane.
