ParallelSort library was updated to version 2.5
aminer10
ParallelSort library was updated to version 2.5..
I have completly changed the mergesort function and it's now working perfectly.
And parallel mergesort is now faster than parallel quicksort and parallel heapsort.
Description:
Parallel Sort Library that supports Parallel Quicksort, Parallel HeapSort and
Parallel MergeSort on Multicores systems. Parallel Sort Library 2.5 uses my
Thread Pool Engine and quicksort many array parts - of your array -  in parallel
using Quicksort or HeapSort or MergeSort and after that it finally merge them
- with the merge() procedure -
- Parallelizing the Sorts:
One way to parallelize the sorts is:
1- Divide the data among the processors
2- Sort the data on the individual processors.
3- Merge the various data
Note that the merge operation is a reduction operation !
In the previous parallelsort version i have parallelized only the sort part, but in this new parallelsort
version i have parallelized also the merge procedure part and it gives better performance.
You can download ParallelSort library version 2.5 from:
http://pages.videotron.com/aminer/
Thank you,
Amine Moulay Ramdane.
