1707 Discussions
Problem when executing code compiled with -parallel flag
jofre
Hi everone,
Well, as the thread title indicates, I am having problems when executing code compiled using the -parallel flag.
There is no error during compilation.
The message I get in the terminal are:
Program Started.
OMP: Warning #2: Cannot open message catalog "libiomp5.cat":
OMP: System error #2: No such file or directory
OMP: Hint: Check NLSPATH environment variable, its value is "(null)".
OMP: Hint: Check LANG environment variable, its value is "fr_FR.UTF-8".
OMP: Info #3: Default messages will be used.
where the first line is from my code, so the code has actually started to execute.
I am using xubuntu9.10 and ifort 11.1.064
As you can guess, I am not an advance user... I have no idea where I can modify the NLSPATH variable, and to change it for what?
Any ideas? I will love to see my code be able to use the two cores of my cpu...
Thanks in advance,
Jofre
TimP
It seems this pertains to whether OpenMP threading library run-time error messages can be displayed, should the occasion arise. Possibly it doesn't know how to deal with French language settings. This doesn't prevent use of 2 cores.
As you must be using an Intel C++ or Fortran compiler, the question would be more topical on the related forum (C++ or linux Fortran).
jofre
Ups, you are right, the code is actually running ok! I presumed that the execution had halted and did "ctrl + C".
Thanks for the hint!
All the best,
Jofre
