Problem
Martin_Fuchs
Hello I have following problem. I want to use mkl on a Intel core2 CPU (Vendor ID: GenuineIntel) using the ifort compiler. I get this error message:
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `__mth_i_dfloatuk'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_orders_chunk8'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_penter'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_lcpu2'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_orders_init8'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_ncpus'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_pexit'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `__fmth_i_dsincos'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `__c_mset4'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `__c_mcopy8'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_p'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_orders_beg'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_scheds8'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_scheds_dyn_init8'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_scheds'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_ncpus2'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `__c_mzero4'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_scheds_dyn_init'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `__c_mcopy8_bwd'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_v'
/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t/libmkl_pgi_thread.so: undefined reference to `_mp_penter_set'
I used this compiler settings:
/home/fuchs/intel/Compiler/11.1/072/bin/intel64/ifort -O3 /home/fuchs/workspace-f90/Schwerefeldbestimmung/*.o RefOrbit.f90 -o RefOrbit -I/home/fuchs/workspace-f90/Schwerefeldbestimmung/ -L/home/fuchs/intel/Compiler/11.1/072/mkl/lib/em64t -lmkl_pgi_thread -lmkl_core -lmkl_intel_ilp64 -lmkl_lapack95_ilp64 -openmp
Can someone help me please...
Michael_K_Intel2
Hi Martin,
the unresolved symbols that you've seen come from the PGI threading library of MKL. As you're compiling and linking with ifort you should remove the PGI library from the command line and replace with either libmkl_gnu_thread.a or libmkl_intel_thread.a.
Does that work out for you?
Cheers,
-michael
Martin_Fuchs
Jep that worked... now I can compile without any errors but when I start the executable it says...
./RefOrbit: error while loading shared libraries: libmkl_intel_thread.so: cannot open shared object file: No such file or directory
Gennady_F_Intel
Martin,
my 2 cents regarding this issue: for the future it would be usefull if you will refer to the MKL Linker Adviser, which will provide thr proper linking line for all most important combinations.
--Gennady
Gennady_F_Intel
did you check LD_LIBRARY_PATH?
Martin_Fuchs
Jepped that worked... Now finally this error
./RefOrbit: error while loading shared libraries: libiomp5.so: cannot open shared object file: No such file or directory
this might be similar I guess...
Martin_Fuchs
LD_LIBRARY_PATH=/DGFI16/home/fuchs/intel/Compiler/11.1/072/lib/intel64:$LD_LIBRARY_PATH
^^ so finally I made it... Thanks so much to every one... !!! With this last line it compiled and worked...
Gennady_F_Intel
Well. Thats fine. Let me add one more comment regarding error while loading shared libraries: libiomp5.so
I noticed you uses MKL version which is bundled with Intel Compiler,
hence in this case all libiomp*.* binary objects are situated into /lib/intel64/ directory,
Where, as I guess in your case == /home/fuchs/intel/Compiler/11.1/072/
--Gennady
