Q&A: Porting to a 64-bit Platform
Intel_Software_Netw1
These questions were received by Intel Software Network Support about the original article located at http://www.intel.com/cd/ids/developer/asmo-na/eng/197664.htm, followed by the responses received:
Q. I have a large project on VCwhich includes some third party .cpp & header files. Now I would like to make it 64-bit .NET platform compatible and that too without using any third party interfaces. What would I need to do? Please help me out in this regard.
A. Removing dependencies on 3rd-party interfaces means implementing equivalent services in your own code without violating the 3rd-party's intellectual property. Once that's been done in the 32-bit version of the code, then go through the process of porting it to 64-bit like any other codebase: Use the /Wp64 flag to find the easy 64-bit issues in your 32-bit code, and then build and test with the 64-bit compiler. Porting the codebase to the .Net interfaces is a similar process, and can be complicated if you are porting from native (C/C++) to managed code (C#) that uses different APIs.
Gina B.
http://www.intel.com/software
email: ISN.support@intel.com
Intel is a registered trademark of Intel Corporation or its subsidiaries in the United States and other countries.
*Other names and brands may be claimed as the property of others.
