1698 Discussions
REP CMPSB, SCASB operation can no longer be used for lock-free algorithms
mugi
Hello
As a result of the 4th Gen. Xeon's support for Fast SHORT REP CMPSB, SCASB, lock-free algorithms using REP CMPSB, SCASB no longer work correctly. For example, the following code will not work correctly:
/* Example of barrier synchronization */
extern bool _scasb(const char*, char, unsigned int);
#define NR_THREADS  8
char   sem[NR_THREADS] = { 0 };
/* This function posts the end of computation for thread #i */
void post_one(unsigned int i) {
	sem[i] = 1;
/* This function waits until all threads have completed their calculations. */
void wait_all() {
	while (!_scasb(sem, 1, NR_THREADS)) { yield(); };
; _scasb for windows
_scasb	PROC
    push   rdi
    mov	   rdi, rcx
    mov    al, dl
    mov    ecx, r8d
    repz scasb
    setz   al
    pop    rdi
    ret
_scasb	ENDP
If Fast Short REP SCASB is enabled, wait_all() may return before all calculations are complete.
Here's an example that makes it a little clearer what's going on.
; 2 bytes of data  FF-FF
data  DB    0FFH
      DB    0FFH
; Loop until data becomes 00-00
Thread1 PROC
    push  rdi
$L1:
    lea   rdi, data
    xor   al, al
    mov   ecx, 2
    repz scasb
    jnz   $L1
    pop   rdi
    ret
Thread1 ENDP
; Repeat changing the first 1 byte of data
Thread2 PROC
$L2:
    mov BYTE PTR data, 0
    mov BYTE PTR data, 0FFh
    jmp $L2
Thread2 ENDP
The value of data can only be FF-FF or 00-FF, so Thread1 should loop forever. However, if Thread1 and Thread2 are executed at the same time, Thread1 will exit the loop.
Here are the results of the actual execution.
0:000> u Thread1
test!Thread1:
00007ff6`e19e1100 57              push    rdi
00007ff6`e19e1101 488d3df81e0000  lea     rdi,test!data (00007ff6`e19e3000)]
00007ff6`e19e1108 32c0            xor     al,al
00007ff6`e19e110a b902000000      mov     ecx,2
00007ff6`e19e110f f3ae            repe scas byte ptr [rdi]
00007ff6`e19e1111 75ee            jne     test!Thread1+0x1 (00007ff6`e19e1101)
00007ff6`e19e1113 5f              pop     rdi
00007ff6`e19e1114 c3              ret
0:000> bp 00007ff6`e19e1113
0:000> g
Breakpoint 1 hit
test!Thread1+0x13:
0:000> r zf
zf=1
0:000> r rcx
rcx=0000000000000001
According to the Intel IA32 Software Developer's Manual, the completion condition for the REPNZ SCASB instruction is either RCX = 0 or ZF = 1. However, it actually completes with RCX > 0 and ZF = 0.
Probably Fast Short REP SCASB loads the same byte twice.
Seems like a bug in Sapphire Rapids to me, what do you think?
