1706 Discussions
Specifying alternate ports using Remote Data collector
Maximillia_D_Intel
I'm trying to use an alternate port under remote data collector and Thread Profiler.
The command on ittserver is:
ittserver -p
ittserver starts up fine and tells me it is using the alternate port, however do I need to do something on the Windows host side? Itriedjust by specifying the IP without port and it did not seem to work - the host could not connect.
I tryadding the port by appending : to the end of the ip, so for me:
10.23.29.176:50004 andVTunedoesn't like the syntax.
I am using Fedora Core 5and at least on my system, the default port, 50002 is in use by something else.
Any help is appreciated.
Max
Victor_Zaguskin
Thread profiler RDC does not support alternative ports.
Victor
