Unexplained speedup how?
aketh_t_
Hi all,
I have got a speedup of approximately 4x with just rewriting a few where statements in my loop to explicit do loops as illustrated below.
Unchanged code
where ( LMASK )
            WORK1(:,:,kk) =  KAPPA_THIC(:,:,kbt,k,bid)  &
                           * SLX(:,:,kk,kbt,k,bid) * dz(k)
            WORK2(:,:,kk) = c2 * dzwr(k) * ( WORK1(:,:,kk)            &
              - KAPPA_THIC(:,:,ktp,k+1,bid) * SLX(:,:,kk,ktp,k+1,bid) &
                                            * dz(k+1) )
            WORK2_NEXT = c2 * ( &
              KAPPA_THIC(:,:,ktp,k+1,bid) * SLX(:,:,kk,ktp,k+1,bid) - &
              KAPPA_THIC(:,:,kbt,k+1,bid) * SLX(:,:,kk,kbt,k+1,bid) )
            WORK3(:,:,kk) =  KAPPA_THIC(:,:,kbt,k,bid)  &
                           * SLY(:,:,kk,kbt,k,bid) * dz(k)
            WORK4(:,:,kk) = c2 * dzwr(k) * ( WORK3(:,:,kk)            &
              - KAPPA_THIC(:,:,ktp,k+1,bid) * SLY(:,:,kk,ktp,k+1,bid) &
                                            * dz(k+1) )
            WORK4_NEXT = c2 * ( &
              KAPPA_THIC(:,:,ktp,k+1,bid) * SLY(:,:,kk,ktp,k+1,bid) - &
              KAPPA_THIC(:,:,kbt,k+1,bid) * SLY(:,:,kk,kbt,k+1,bid) )
          endwhere
Changed code
do j=1,ny_block
           do i=1,nx_block
            if ( LMASK(i,j) ) then
            WORK1(i,j,kk) =  KAPPA_THIC(i,j,kbt,k,bid)  &
                           * SLX(i,j,kk,kbt,k,bid) * dz(k)
            WORK2(i,j,kk) = c2 * dzwr(k) * ( WORK1(i,j,kk)            &
              - KAPPA_THIC(i,j,ktp,k+1,bid) * SLX(i,j,kk,ktp,k+1,bid) &
                                            * dz(k+1) )
            WORK2_NEXT(i,j) = c2 * ( &
              KAPPA_THIC(i,j,ktp,k+1,bid) * SLX(i,j,kk,ktp,k+1,bid) - &
              KAPPA_THIC(i,j,kbt,k+1,bid) * SLX(i,j,kk,kbt,k+1,bid) )
            WORK3(i,j,kk) =  KAPPA_THIC(i,j,kbt,k,bid)  &
                           * SLY(i,j,kk,kbt,k,bid) * dz(k)
            WORK4(i,j,kk) = c2 * dzwr(k) * ( WORK3(i,j,kk)            &
              - KAPPA_THIC(i,j,ktp,k+1,bid) * SLY(i,j,kk,ktp,k+1,bid) &
                                            * dz(k+1) )
            WORK4_NEXT(i,j) = c2 * ( &
              KAPPA_THIC(i,j,ktp,k+1,bid) * SLY(i,j,kk,ktp,k+1,bid) - &
              KAPPA_THIC(i,j,kbt,k+1,bid) * SLY(i,j,kk,kbt,k+1,bid) )
            endif
            enddo
          enddo
We are unable to try Vtune as the code ran for eternity, like 1 day. Also no info as to why it showed such high speedup was not explained. Just a few red bars with time taken. They were in agreement to the time showed by omp timers added b/w the loops.
The compilation of unchanged code was with -O3 while changed code was with -O2. I can clearly rule out loop fusion as a reason(fusion of loops of work1, work2 which are hidden in : style language). As per the opt-report loops we fused for original code.
I can guarantee no Openmp was implemented. All flags are similar in both cases(except O3).Any explanation why is speedup as high as 4X.
UPDATE
Hi I did check the optrpt and found the following for unchanged and changed code
unchanged code
            remark #15448: unmasked aligned unit stride loads: 13
            remark #15449: unmasked aligned unit stride stores: 3
            remark #15450: unmasked unaligned unit stride loads: 3
            remark #15455: masked aligned unit stride stores: 6
            remark #15456: masked unaligned unit stride loads: 16
changed code
      remark #15454: masked aligned unit stride loads: 2
TimP
It does look like the fusion of your WHERE version is incomplete, possibly as a consequence of the rank 2 array assignments, or possibly because that style is not so frequently used in critical performance situations which the compiler has been trained to optimize.  You must recognize that the syntax of WHERE requires the compiler to start out by distributing the conditional to each individual assignment, so there is a lot more work to be done to get back to full sharing of operands by loop fusion.
jimdempseyatthecove
What I suspect to be happening is, in the 4x test case, the array LMASK is sparsely (or at least not densely) populated with .true..
Under this circumstance, the code may have been performing masked load/store operations where the entire mask is .false..
Jim Dempsey
