Intel® Moderncode for Parallel Architectures
Support for developing parallel programming applications on Intel® Architecture.
Using intel mpi in parallel ANSYS fluent with AMD processors
milad_m_
HI
I set up and use successfully this tutorial (https://goo.gl/Ww6bkM) for clustering 2 machine to run the ansys fluent 17.2 in parallel mode. machine 1 (node1) is win server 2012 R2 64bit and machine 2 (node2) is win 8 64bit. both of them use Intel core i3 3.10 GHZ and 8GB memory. this tutorial use intel mpi for paralleling.
Know i set it up for 2 machine with same OS like above, but with quad core AMD opteron processor 2378 2.4GHZ and 16 GB memory.
When i run for parallel processing according the tutorial this error appear.
https://goo.gl/p3LaLf
Is it possible that intel mpi dont compatible with this AMD processors for parallel run or other reason has been caused this? what should i do?
thanks.
TimP
No, there is no option to make impi refuse to run on amd, although there are such for intel compilers. The hpc cluster forum would be more suitable if you would grant permission to see your error message.
milad_m_
thanks Tim.
milad_m_
I find it. i changed all OS to win 8.1 and it was solved.
