cache L1 size
sammoura
i'm using a laptop that his processor is intel core 2duo cpu T7500 @2.2Ghhz.
I know that the L2 cache size is 4mega, or i don't know the size of L1.
Some one can help me please and tell me this information, i searched in the net but no results, only the size of L2 is known.
Thanks a lot.
AwesomeMachine
Quoting sammoura
Thanks a lot.
It's 32k. If you run into this question about a different processor, or any hardware question, boot the machine using Knoppix Linux live CD distro, and from a virtual terminal run:
for cpu info,
cpuinfo | less
for hard drive info,
hdparm -I /dev/sda | less
for hardware in general,
hwinfo or dmidecode
for pci hardware,
lspci -vvv | less
for scsi hardware,
lsscsi | less
for usb hardware,
lsusb
for onboard sensor device chips,
sensors-detect
for bios entry points and/or dump,
biosdecode
control cpu speed,
cpuspeed
Display or change ethernet chip settings,
ethtool
control fan speed,
fancontrol
identify FIR chip (infrared)
findchip
huge amounts of hardware info, bios dumps, memory dumps;
lshal -vvv
examine ISA registers
isadump
set ISA registers,
isaset
Reads ATA SMART data
skdump --overall /dev/sda
dump/read/change video bios,
vbetool
Ok, that's enough stuff for today. If you need help with any of these commands, type:
man command
