firstprivate is hungry
ifx
i am learning openmp and i want to parallelize one part of my simulation routine with linked list structure. Following some examples from the net, i modified my code, but it does not work according my expectations. The parallel part of the code is draining my memory. I need to iterate several times through the complete linked list. Every time when the "firstprivate" makes a private copy of the Item from the linked list, it is taking some part of the memory, but after the job is done and one "task" is closed, the memory is not released. Is it normal or am i doing something wrong? How can i solve this?
thank you for your tips. test example: (compiled with: icc -g -O0 -openmp -o test ./test.cc )
critical part of test routine:
[cpp]for(i=1;i<=1000;i++)  // MORE interations needs MORE memory
pP = pFirst;
#pragma omp parallel num_threads(2)
#pragma omp single nowait
while (pP != NULL)
#pragma omp task private(l) firstprivate(pP)
//do some dummy job
l = pP->nr;
pP->y = l;
pP = pP->pNext;
} // end of single nowait
} // end of parallel region
} // end of for
[/cpp]
Complete test routine:
ATTENTION!: following example can block your PC.
[cpp]#include
#include
#include "omp.h"
struct ITEM
double z, y;
int nr;
ITEM *pNext; // pointer to next
ITEM *pPrev; //pointer to previous
/********** prot. *********/
void AppendItem(ITEM *pP);
void RemoveItem(ITEM *pP);
void DeleteAllItems(void);
// Init
ITEM *pFirst, *pLast;
ITEM *pP;
ITEM *pTemp;
int main()
int l, i;
// create linked list
for(l=1;l<=1000;l++){
pP = new ITEM; // get mem for item
pP->nr = l;
AppendItem(pP);
for(i=1;i<=10000;i++)
pP = pFirst;
while (pP != NULL)
//do some dummy job
l = pP->nr;
pP->y = l;
pP = pP->pNext;
DeleteAllItems();
return 0;
// Appends a node to the end of the list
if (pFirst == NULL) {
pFirst = pP;
pP->pPrev = NULL;
else {
pLast->pNext = pP;
pP->pPrev = pLast;
pLast = pP;
pP->pNext = NULL;
// Removes the specified node from the list
if (pP->pPrev == NULL) pFirst = pP->pNext;
else pP->pPrev->pNext = pP->pNext;
if (pP->pNext == NULL) pLast = pP->pPrev;
else pP->pNext->pPrev = pP->pPrev;
// Deletes the entire list
void DeleteAllItems()
while (pFirst != NULL){
RemoveItem(pFirst);
RemoveItem(pP);}
[/cpp]
Om_S_Intel
Quoting - ifx
pP = pFirst;
while (pP != NULL)
//do some dummy job
l = pP->nr;
pP->y = l;
pP = pP->pNext;
} // end of for
[/cpp]
[cpp]#include
#include
#include "omp.h"
struct ITEM
double z, y;
int nr;
// Init
ITEM *pP;
ITEM *pTemp;
int main()
int l, i;
pP->nr = l;
AppendItem(pP);
pP = pFirst;
while (pP != NULL)
//do some dummy job
l = pP->nr;
pP->y = l;
pP = pP->pNext;
DeleteAllItems();
return 0;
pFirst = pP;
pP->pPrev = NULL;
else {
pLast->pNext = pP;
pP->pPrev = pLast;
pLast = pP;
pP->pNext = NULL;
RemoveItem(pFirst);
RemoveItem(pP);}
[/cpp]
I think you have discovered an issue with Intel C++ compiler.
Also you are missing "delete pP;" inRemoveItem().I think you need to remove the statement "RemoveItem(pP);" from DeleteAllItems().
