function call to ?1memcpy cannot be vectorized
Page__Mike
The following lines of code generates reports on failure to parallelize and to vectorize:
      allocate(particles(nrp+ngp))
      particles(    1:nrp) = rparticles
      particles(nrp+1:   ) = gparticles
declarations:
      use particle_mod   , only: particle_t
      type(particle_t), intent(in   ) :: rparticles(nrp), gparticles(ngp)
reports:
LOOP BEGIN at calc.f90(76,7)
   remark #17104: loop was not parallelized: existence of parallel dependence
   remark #17106: parallel dependence: assumed OUTPUT dependence between call:?1memcpy (76:7) and call:?1memcpy (76:7)
   remark #17106: parallel dependence: assumed OUTPUT dependence between PARTICLES(:) (76:7) and PARTICLES(:) (76:7)
   remark #17106: parallel dependence: assumed OUTPUT dependence between PARTICLES(:) (76:7) and rparticles(:) (76:7)
   remark #17106: parallel dependence: assumed OUTPUT dependence between rparticles(:) (76:7) and PARTICLES(:) (76:7)
   remark #17106: parallel dependence: assumed OUTPUT dependence between rparticles(:) (76:7) and rparticles(:) (76:7)
   remark #15527: loop was not vectorized: function call to ?1memcpy cannot be vectorized
LOOP END
LOOP BEGIN at calc.f90(77,7)
   remark #17106: parallel dependence: assumed OUTPUT dependence between call:?1memcpy (77:7) and call:?1memcpy (77:7)
   remark #17106: parallel dependence: assumed OUTPUT dependence between PARTICLES(:) (77:7) and PARTICLES(:) (77:7)
   remark #17106: parallel dependence: assumed OUTPUT dependence between PARTICLES(:) (77:7) and gparticles(:) (77:7)
   remark #17106: parallel dependence: assumed OUTPUT dependence between gparticles(:) (77:7) and PARTICLES(:) (77:7)
   remark #17106: parallel dependence: assumed OUTPUT dependence between gparticles(:) (77:7) and gparticles(:) (77:7)
LOOP END
particle_t defined as:
  public  particle_t
  public  print_particles
  type, bind(C)  :: particle_t
     real(rt)    :: pos(3)     !< Position -- fortran component  1
     real(rt)    :: radius     !< Radius   -- fortran component  4
     real(rt)    :: volume     !< Volume   -- fortran component  5
     real(rt)    :: mass       !< Mass     -- fortran component  6
     real(rt)    :: density    !< Density  -- fortran component  7
     real(rt)    :: omoi       !< One over momentum of inertia -- fortran component 8
     real(rt)    :: vel(3)     !< Linear velocity              -- fortran components 9,10,11
     real(rt)    :: omega(3)   !< Angular velocity             -- fortran components 12,13,14
     real(rt)    :: drag(3)    !< Drag                         -- fortran components 15,16,17
     integer(c_int)  :: id
     integer(c_int)  :: cpu
     integer(c_int)  :: phase
     integer(c_int)  :: state
  end type particle_t
Page__Mike
I have continued to look at this issue and have encountered information on streaming stores and non temporal writes
https://software.intel.com/en-us/articles/memcpy-memset-optimization-and-control
adding directives:
!DIR$ vector nontemporal
!DIR$ simd
or adding the compile option -qopt-streaming-stores
simd vectorizes the loops but the compiler reports
scalar cost:  89
vector cost: 159.87
​will be testing the change soon
TimP
Is the "non-vectorized" compilation using a memset library function, as expected?  The library call may well be faster, assuming those vectors are long enough. If short, alignment may play a role, but inline optimization could depend also on length being known at compile time.  It this fragment is critical for you, you should at least check the opt-report for the vectorized version, preferably look at the generated code (possibly under Advisor or VTune)?
Isn't the legacy !dir$ simd deprecated?
This forum itself may be going in the direction of deprecation.  Intel announced a committee to make recommendations on the roles of the various forums; meanwhile, your question might have got more attention on one of the Fortran forum sections.
Page__Mike
"Is the "non-vectorized" compilation using a memset library function, as expected?"
Not that I can see:
nm of the object file:
0000000000000000 T this_code
0000000000000000 d this_code$format_pack.0.1
                 U cfrelvel_module_mp_cfrelvel_
                 U discretelement_mp_des_coll_model_enum_
                 U discretelement_mp_des_crossprdct_
                 U discretelement_mp_des_etan_
                 U discretelement_mp_hert_kn_
                 U discretelement_mp_kn_
                 U discretelement_mp_mew_
                 U for_alloc_allocatable
                 U for_check_mult_overflow64
                 U for_dealloc_allocatable
                 U for_stop_core
                 U for_write_seq_fmt
                 U for_write_seq_fmt_xmit
0000000000000000 r __STRLITPACK_10
0000000000000048 r __STRLITPACK_12.0.1
0000000000000050 r __STRLITPACK_13.0.1
0000000000000000 r var$145.0.1
"Isn't the legacy !dir$ simd deprecated?"
Not sure.
I am working from a 2014 Intel article:
https://software.intel.com/en-us/articles/memcpy-memset-optimization-and-lcontrol
jimdempseyatthecove
Try padding your particle structure such that is becomes a multiple of the vector width (16, 32 or 64 bytes as the case may be).
Jim Dempsey
Page__Mike
Jim,
Thank you for your response. I have passed it along to a colleague who is actually working with the code.
I will do my best to post any resolution here or may continue with more questions.
Page__Mike
Jim,
Your suggestion was reported as being helpful though I have not been able to test and measure the improvements yet myself.
Thanks Again.
