Intel® Moderncode for Parallel Architectures
Support for developing parallel programming applications on Intel® Architecture.
loop optimization for non-uniform access to an array
Abhishek_S_4
I have following kind of loop that I am looking to optimize for intel compiler 18.0
SomeData* sourcePtr = GetMySourceSomeData();
SomeData* saPtr = GetMySomeDataPointer();
int size = GetSizeSomeData(saPtr);
// indexArray has series of indices based on some business logic, can be considered random.
int* indexArray = GetRandomIndexArray();
SomeData zero = SomeData(0);
//below loop needs to be optimized.
for (int point = 0; point < size; indexArray++, saPtr++, point++)
      *(saPtr) = (GetDecisionMaker(point))?sourcePtr[*(indexArray)]:zero;
// GetDecisionMaker(point) returns a boolean value based on some business logic, can be considered random.
With intel compiler 13.0 we had a good performance, but with 18.0 we don't get a good performance.
All help is welcome!
jimdempseyatthecove
Try this first:
for (int point = 0; point < size; point++)
      saPtr[point] = (GetDecisionMaker(point))?sourcePtr[indexArray[point]]:zero;
IOW use the index point as opposed to advancing pointers (which may have lifespan after loop).
Please describe GetDecisionMaker.
Be aware that the newer CPU architectures have Scatter/Gather instructions. If the type of SomeData is a "standard" type (char, short, int, float, double, ...) .AND. if the GetDecisionMaker is suitable to (vectorwise) generate a mask, then the loop may be vectorized by the compiler (assuming appropriate compiler optimization options and/or #pragma are used).
Jim Dempsey
Abhishek_S_4
Thank you Jim for the reply!
I vectorized GetDecisionMaker(point) as decisionArray and now I have below code. saPtr points to array of structure containing two integers.
 typedef struct SomeArrayStruct { int x; int y; } SomeArray;
      saPtr[point] = decisionArray[point] ? sourcePtr[indexArray[point]]:zero;
the performance is still the same as previous code, no improvement.
~Abhishek
jimdempseyatthecove
__int64* saPtrX = (__int64*)saPtr;
__int64* sourcePtrX = (__int64*)sourcePtr;
__int64 zero = 0;
      saPtrX[point] = decisionArray[point] ? sourcePtrX[indexArray[point]]:zero;
Jim Dempsey
jimdempseyatthecove
Note, the earlier post relating to scatter/gather requires CPU that supports this and compiler option and/or #pragma hint to use this.
Jim Dempsey
