Intel® Moderncode for Parallel Architectures
Support for developing parallel programming applications on Intel® Architecture.
parallel studio XE cluster edition initialization behavior
Othman_B_Intel
Dear colleagues,
I recently noticed a behavior I did not expected with Parallel Studio XE Cluster Edition 2017. It happens also for 2016.
To use PSXE 2017, I source /opt/intel/parallel_studio_xe_2017.2.174/psxevars.sh (nothing new, this is the last version actually).
But, I kept the old versions. And when I source /opt/intel/parallel_studio_xe_2017.1.043/psxevars.sh, the compilers points to the ones in /opt/intel/parallel_studio_xe_2017.2.050.
To me, the expected behavior is that when I source /opt/intel/parallel_studio_xe_2017.1.043/psxevars.sh the compilers points to the ones in /opt/intel/parallel_studio_xe_2017.1.043...
About VTune, I expect that this is always the last that is executed, as well as Advisor.
The advantage is that it keeps consistancy among the development tools (same version of the compiler, mpi, mkl...). Moreover, why keeping the script psxevars.sh in specific locations identified by version number if it is to load the last version of the tools?
What is your opinion?
Othman.
gaston-hillar
Valued Contributor I
I think the right place to post this question is the Intel C++ Compiler forum. Here is the link: https://software.intel.com/en-us/forums/intel-c-compiler
SergeyKostrov
Valued Contributor II
>>...I kept the old versions... I tried to keep old versions / updates of Intel PS XE Cluster Edition for Linux and decided it is better to remove old versions to avoid any problems similar to what you've described.
