Some time ago we downloaded and installed bios version 064 on all the company's NUCs.
I was looking for a new bios version and noticed that this version is no longer available.
What happened? Should I go back to version 062? (Latest available on website today)
Lucius, Thank you for posting in the Intel® Communities Support.
In reference to your question about what happened with BIOS version 0064 and if you should reinstall BIOS version 0062, I will double-check those details and I will post the answer as soon as possible.
Albert R.
Hello Lucius, I just received an update on this matter.
The BIOS 0064 was removed by specific issues that were reported. If your Intel® NUCs are not showing any issues then there is no problem in staying with this version.
Albert R.
Hey Alberto,
Can you be a little more specific? I ask because I'm having an issue (Link below) which I think a BIOs update would fix.
Intel NUC 11 Extreme i9 - GPU or PCIE issue - Intel Communities
Thank you
Peter
Pete748, Thank you for posting in the Intel® Communities Support.
In that case, please keep checking your thread for a possible solution and further updates on this matter. We will further assist you on your original thread.
Albert R.
