I'm having problem playing some movies.. audio plays fine but can't see anything(only get flashing black screen).
Don't know much about video codec, but it seems like all the movies with "Decoded format: Planar 4:4:4 YUV 10-bit LE" have this issue.
But they worked fine on my PC(i7 8700K, GTX1080), all movies are .mkv file and I'm using latest VLC Player(3.0.5).
Anyone else have same issue? or know the solution? Thanks
Example of a movie that doesn't work:
https://erai-raws.info/anime-list/fate-apocrypha/
p.s. bit more info..
Movies with Video Codec: H264 - MPEG-4 AVC (part 10) (avc1) & Audio Codec: MPEG AAC Audio (mp4a) = works fine.
Movies with Video Codec: H264 - MPEG-4 AVC (part 10) (avc1) & Audio Codec: FLAC (Free Lossless Audio Codec) (flac) = some works, some doesn't.
Decoded format: Planar 4:4:4 YUV 10-bit LE = doesn't work
Decoded format: Planar 4:2:0 YUV 10-bit LE = works
Hi Leonardo,
Thank you for the reply, but I still have same problem. i.e. can't play those videos.
Here is link for another video that doesn't play.
https://erai-raws.info/anime-list/nanatsu-no-taizai-imashime-no-fukkatsu/
I've also attached two files(Intel SSU and Radeon Vega report) as you requested.
O̶n̶e̶ ̶P̶u̶n̶c̶h̶ ̶M̶a̶n̶ Saitama
Hello Leonardo,
• Are you doing the testing streaming the videos or do you download the videos? I just download videos.
• If you are streaming the videos what browser are you using? Does the same behavior happen in other browser? not applicable
• If the videos are downloaded what software are you reproducing the videos? I used VLC Player v3.0.5, now I use VLC Player v3.0.6.
I don't think it's my system or setup, but NUC8i7HVK itself. I have all the latest drivers installed.
Do you also have NUC8i7HVK? if yes, can you play these videos?
I would be curious to know if anyone else with NUC8i7HVK can play these videos..
Saitama
