Intel® NUCs
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11990 Discussions
New NUC NU6CAYH. No Intel splash screen.
CKafo
Changed cables, monitors. It is configured with SSD/Windows and 2 4GB memory which came out of a running NU6CAYH. I also inserted a flash drive with Windows. Thank you
LeonWaksman
1. What is the P/N of the SODIMM you have installed?
2. Is the LED blinking if you try to power ON your NUC without RAM memory installed?
3. Try to power ON your NUC only with one memory module at time.
Leon
ffake
Hi I am having the same problem.
My ram is M471B5173QH0-YK0.
The LED blinked when there's no ram installed, also I can hear beeps from the headphone.
I've tried booting with only one ram, but nothing changed.
What could be causing the problem?
CKafo
Thank you for the tip.
  1. ripjaws F3-1866C-4GRSL (it worked in an identical NUC last week)
  2. Yes, blinks then goes off
  3. Tried with no memory and one module in the top. Same result
LeonWaksman
Try to recover bios with the security jumper removed. Download the latest bios file AY0059.BIO ​https://downloadcenter.intel.com/download/28478/BIOS-Update-AYAPLCEL-86A-?product=95062
Save this file on USB stick fully formatted to FAT32 in Windows. Remove the yellow security jumper and power ON your NUC with the USB inserted. The recovery should start automatically ​and end within few minutes.
Leon
