Intel® NUCs
Support for Intel® NUC products
12101 Discussions
No way to set 5K resolution for LG 5K display in Ubuntu Linux
Jeffrey2019
I tested with Ubuntu 18.04.3, Hades NUC is natively supported, no need to install patches, same for Ubuntu 19.04.
But for LG 5K display, I can't figure out a way to configure 5K resolution as there are 2 DP displays in system settings.
BTW, I must disable intel graphic card in BIOS, otherwise I can't boot into Ubuntu with only LG 5K display which has only thunderbolt 3 interface.
AndrewG_Intel
Hello Jeffrey2019,
Regarding your inquiry about 5K resolution, most Linux-based* distributions include Intel® Graphics Drivers, however, you may also check the following link for Intel® Graphics drivers for Linux*:
I noticed you mentioned you have to disable Intel® Graphics card in BIOS. This issue is already reported in the following link regarding Intel® NUC NUC8i7HxK: Troubleshooting Linux* Issues on Intel® NUCs
Could you please confirm the exact model of the Intel® NUC?
It is worth mentioning that Intel hasn't validated these operating systems and the support for Linux is limited. We recommend you use the latest kernel. We also recommend you to contact the UBUNTU® distribution resources or The UBUNTU® community* for additional information and support options.
Note: This link is being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Andrew G.
A Contingent Worker at Intel
