I bought the Intel nuc8i7beh and successfully used it for 2 days. After that, I changed the led glow power in the settings and I started having problems with RAM (lot of errors in memtest).
After that the seller changed my NUC to another. First of all I tested my ram and everything was fine, but when I changed LED power - RAM errors returned. (these RAM boards works fine in my notebook)
Dear Intel, pls check this strange fact. Thank you.
Provide the EXACT model number of your memory sticks.
Doc
How did you test your DRAM?
What exact change(s) did you make in the BIOS Configuration?
Did the power supply get replaced along with the NUC itself?
What else do you have plugged into the system?
Hello AGrap,
Thank you for posting on the Intel ® communities.
Were you able to check the previous posts?
Let me know if you need more assistance.
David V
A Contingent Worker at Intel
Hello AGrap,
Please contact us if you have any additional questions.
David V
