Intel® NUCs
Assistance in Intel® NUC products
All support for Intel® NUC 7 - 13 systems is transitioning to ASUS. Read more.
13483 Discussions
RTX2060 Not working with Intel DZ68BC
RMAEloy
First of all, forgive my bad English
I bought a RTX 2060 MSI Ventus 12Gb and when I put it in the DZ68BC it gets stuck at the boot screen for like 10 seconds, then it gives a short beep and resets.
the third time it only shows a black screen, 10 seconds pass and it resets again.
I use the power supply with a GTX 960 working 100% without problem on that same motherboard.
Thanks for any help you can give me.
Ante de nada, perdonen mi mal ingles
Compre una RTX 2060 MSI Ventus 12Gb y cuando la coloco en la DZ68BC se queda pegada en la pantalla de arranque como 10 segundo, luego emite un pitido corto y se resetea.
a la tercera vez solo muestra la pantalla en negro, pasan 10 segundos y se resetea de nuevo.
La fuente de poder la uso con una GTX 960 trabajando al 100% sin problema en esa misma placa madre.
Gracias por la ayuda que me puedan prestar.
AlHill
I would not expect that graphics card to work with a 11-year old motherboard.
n_scott_pearson
Super User Retired Employee
Nope, very unlikely that it will work.
Sorry,
