NUC 8i7HVB Serial BTHN0180084H
Sudden loss of NUC sound output, both Bluetooth and direct cable. There is only "static" on all sound output. Sounds like a continuous tiny rapid machine-gun "pop-pop-pop."
All my listening devices receive the static noise from both web and computer outputs.
Intel online check shows all my drivers up to date.
Your help very welcome. Thanks
Hello Kupuna,
To have a better understanding of your issue, please provide me with the following:
- When did the issue start?
- Was there a major hardware or software change before the issue started?
- What are the models of the audio devices you have tried?
- What audio outputs have you tried?
- Create a report using the Intel
System Support Utility (Intel SSU) - Download the Intel SSU (https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-window...)
- Open the application and click on "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click on "Next"; then "Save."
Jean O.
Jean, Thank you for your inquiry.
My sound problem was solved by uploading a recent Win 11 update. Now running V21H2 - Build 22000.708
I'm sorry to take up any head-space at Intel since it appears to have been a MS problem.
Greg Schultz (Kupuna)
Hello Kupuna,
We are glad to know you found a solution, since the thread is solved we will close it now.
Please keep in mind that this thread will no longer be monitored by Intel. Thanks for your understanding.
Jean O.
