I would like to integrate this computer on a UAV and I cannot find the weight. Does someone know where to find it? It would be nice also to know the weight without the case.
Here I leave the link:
https://www.intel.com/content/www/us/en/products/boards-kits/nuc/mini-pcs/nuc7i7bnkq.html Intel® NUC 7 Enthusiast Mini PC - NUC7i7BNKQ with Windows* 10Link Copied
Hello marchal_dlr
I understand that you need to inquire into the weight specifications for our Intel (r) NUC7i7BNKQ,
In this case since the information is not handy, we are going to escalate this in order to check if the information is available, this will delay our answers, however I will reach you back as soon as we have news.
I hope this helps.
Diego S.
Hi marchal_dlr,
Unfortunately we dont have the weight officially documented so I did it myself and the unit weight is approximately 1 pound.
I hope this helps,
Ronny G
Hi rguevara,
Thank you for your answer, it is really helpful!
Best,
Juan Marchal
For some reason I cannot create a new topic in intel forums, so I'll add to this question:
I had asked for the weight for the NUC7i7DNHE previously, and I couldn't get a good response. I have one of the units in hand now, and here are the weights I measured (using a cheap digital postal scale). Hopefully others can benefit from this as well:
Full-up NUC7i7DNHE (as delivered, no memory or hard drive): 601 grams
NUC7i7DN PCB (no memory or hard drive, no network card): 202 grams
plastic lid: 25 grams
plastic antenna surround from top (under lid): 15 grams
Metal fan surround/PCB mount: 81 grams
SATA Bracket and cable harness: 46 grams
Metal base with screws, no sata bracket: 115 grams
metal case sides (aluminum surround): 86 grams
metal bulkhead connector: 10grams
RAM heat spreader (metal bracket on top of sata tray): 16 grams
WIFI card: ~6 grams
1 stick RAM, 16GBytes (not intel): 10 grams
M.2 SSD 512GB (not intel): 8 grams
