Intel® NUCs
Support for Intel® NUC products
Do you have improvements you would like us to make on this community site? If so, we would love to hear your feedback! Click here for an 8 question survey. Thanks!
11283 Discussions
how power on nuc 5i7ryh with keyboard or external button?
CMore4
My system needs to turn on the nuc of which I speak so that it is not with the physical button since there is no access to it.
What are the ways to turn it on?
There is a way to turn it on without need sleep mode??
Thank for the info.
Community Manager
I'm pretty sure there's an option in BIOS that lets you use the keyboard to turn the NUC on. 99% sure.
You can also wake from network access within BIOS.
Third option is that there are internal headers from which you can extend a wire which you use to turn the NUC on and off with. That way you can still have a physical button if you have the NUC hidden somewhere.
Community Manager
Thank you very much to jbabels for the information provided previously.
carmor, Thank you very much for joining the Intel® NUC communities.
To answer your question, if the NUC is off, in order to turn it on externally you can try the CIR feature with a remote control, or as it was mentioned previously, you can always use the internal headers of the NUC to extend a wire for power.
There is no an option in the BIOS that allows you to turn the NUC on with a keyboard. In regard to the wake on LAN option, it will work only to wake the NUC from soft off or S5 state, it will not work if the NUC is completely off.
Any further questions, please let me know.
Alberto
