Intel® Optane™ Memory
AYUDA PORFAVOR
Brayan_9
Hola buenas tardes,  me presento so Brayan Duque me sale esta notificación y no se que hacer,me preocupa esto ya que mi equipo es nuevo, porfavor ayuda. GraciasWhatsApp Image 2023-02-20 at 1.42.02 PM.jpeg
n_scott_pearson
I am sorry, but we provide support in English only, using translation tools for everything else - but we cannot translate text in an image.
At the highest level, I can see that you have received a report of a S.M.A.R.T. event. This is typically what happens when a hard drive or SSD is notifying you of its pending failure. If this is the case, you should, as soon as possible, copy all important data off of this drive and get a replacement.
Now, it is possible that this report is spurious. Is this the first time that you have seen this alert or is it being reported regularly? If the hardware is new, I would be contacting your system provider regarding this issue.
Hope this helps,
n_scott_pearson
Hope this helps,
