Intel® Optane™ Memory
1391 Discussions
Can i put ddr4 2400mhz ram with ddr4 1333mhz ram?
sjosh13
I am going to buy a laptop which comes with pentium 4417u , 4gb ddr4 1333mhz ram, i think i should put 4gb more in it, but in market 4gb with 2400mhz is available, should i go?
LeonWaksman
1. Your question is not related to Optane Memory. This is Optane forum.
2. The 2400MHz may not work in your in your laptop. You need check if this is compatible memory.
3. Also this is not good idea to work with different memory modules, since they will not work in double channel mode.
4. What is your laptop model?
Leon
LeonWaksman
Leon
