Intel® Optane™ Memory
1403 Discussions
Optane linked Data Drive (D:) is missing
JAgui17
After a "system cleanup" I got an error message indicating there was a problem with my Optane memory in the Intel Rapid software.
I decided to reboot the system, but after that my D: drive (my data drive, which was attached to the Optane Memory, not the system drive "C:") was inaccessible by my Windows 10 Pro OS. The Intel Rapid software showed that the Optane memory was deactivated.
I need to recover my information, allocated in my D drive. Please, advise.
Thank you.
AlHill
Whose "system cleanup" did you use? I hope NOT ccleaner and/or their registry cleaner.
Doc
JAgui17
I use Norton Utilities and AVG PC TuneUp.
AlHill
When you use tools like that, you use them at your risk. Optane is difficult enough, without having some "cleanup" tool pretending to know what can and cannot be deleted.
I hope you had a backup. If so, start the repairing and restore, and do not use those cleanup tools again.
Sorry, but I have seen too many users get taken by the "snake oil" magical promises of these tools.
Doc
JAgui17
I do have a backup, but is not up to date.
Thinking ahead, while looking for a solution to my present problem: do you have a suggestion about software options to keep Windows 10 in shape?
Thank you.
AlHill
Personally, I do not trust any cleanup tool or registry tool, especially ccleaner. As far as maintenance on W10, their Storage Sense for temporary files seems to do a fair job, without trying to be the "be-all" cleanup tool. Also, W10 disk cleanup (which MS seems focused to get rid of) is a long time tool used by a lot of people. Again, I do not trust anything, especially stuff that messes with the registry.
I take a backup every Friday, whether I need to or not. It is a discipline, it is a practice. And, it has saved me. I also have turned on checkpoints.
I have Optane on one of my machines. When I take a backup of that machine, I disable optane, take the backup, and then enable optane. Thus, if something goes wrong with the pair, I have a good backup of the drive without optane that I can restore to another drive, or do another pairing with optane.
None of this easy. But, it is a way to ensure my data is safe.
Doc
