Intel® Optane™ Memory
1391 Discussions
Cannot start "Intel® Optane™ Memory And Storage Mngmt" as User -> Workaround found
kpav
Dear support team,
Win 10, 64 bit, Version 2004
I just installed (as User in domain network) the current "Intel Optane ....." from Microsoft Store, but I cannot start it:
When I try to launch it (either from the Store button or from the start menu) two UAC pop up successively, where I enter the credentials from  a local admin account, but after that a Error MessageBox appears:
"C:\Program Files\WindowsApps\AppUp.IntelOptaneMemoryandStorageManagement_17.9.1008.0_x64__8j3eq9eme6ctt\RstHSA.Wpf\RstHSA.Wpf.exe" konnte nicht gefunden werden. Stellen Sie sicher, dass Sie den Namen richtig eingegeben haben und wiederholen Sie den Vorgang.
In fact the exe does exist at this place.
Then I logged into the same computer with the local admin account, I had to install the app from Store again, and here it works!
Just tested: Back to my usual login as domain user -> now it works here as well.
kpav
Hi Josh,
thanks for your reply, yes with the work around it is ok, you can close this issue.
kpav
JosafathB_Intel
Hello, kpav.
Thank you for contacting Intel® Memory and Storage support.
As we understand, you needed assistance with your Intel® Optane™ Memory Series, due to an error at the moment of trying to run the tool. If we infer correctly, you already solved the issue by using the Administrator account in your PC and now it is working.
We appreciate the time you took to share your findings and the solution with the community, and we will like to know if you need further assistance, or if we can close this inquiry now?
We will be looking forward to your reply.
Josh B.
A Contingent Worker at Intel®
JosafathB_Intel
Hello, kpav.
We were reviewing your community thread, which is related to your Intel® Optane™ Memory, and we would like to know if you were able to review our previous post and if you needed further assistance.
Have a nice day.
Best regards.
Josh B.
kpav
Hi Josh,
kpav
JosafathB_Intel
Hello, kpav.
Thank you for your reply,
As per your consent, we will close this community thread. If you need further assistance related to the Intel® Optane™ Memory, please do not hesitate to contact us back.
Josh B.
