Intel® Optane™ Memory
공지
1391 토론
Dell inspiron 5593 how do i accelerate my intel optane memory
kweniiii
초보자
6,912 조회수
hello, how do i accelerate my intel optane memory it keeps saying "you have no valid disk pair in your system"
i'm new to laptops so i don't really know how this works??
0 포인트
1 솔루션
AlHill
수퍼 사용자
6,908 조회수
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
원본 게시물의 솔루션 보기
16 응답
kweniiii
초보자
6,911 조회수
do i have to enable it? i search on google on how to but when i search for Intel Rapid Storage it doesn't appear. Do i not i have it?
0 포인트
AlHill
수퍼 사용자
6,909 조회수
kweniiii
초보자
6,897 조회수
0 포인트
kweniiii
초보자
6,893 조회수
here is my system information
0 포인트
JosafathB_Intel
중재자
6,881 조회수
Hello, kweniiii,
Thank you for contacting Intel® Memory and Storage support.
We do not see any file attached to your post, would you mind to try again to upload the SSU logs, to review your current configuration, and to continue with the troubleshooting.
We will be looking forward to your reply.
Josh B.
A Contingent Worker at Intel®
0 포인트
JosafathB_Intel
중재자
6,866 조회수
Hello, kweniiii,
We were reviewing your community thread related to your Intel® Optane™ Memory Series, and we would like to know if you were able to review our previous post and if you needed further assistance.
Have a nice day.
Best regards.
Josh B.
0 포인트
JosafathB_Intel
중재자
6,847 조회수
Hello, kweniiii,
We were reviewing your community thread related to your Intel® Optane™ Memory Series, and we have not heard back from you in a while, so we will proceed to close this inquiry now.
If you need further assistance, please post a new question.
Josh B.
0 포인트
Muhammad_Ahsan_Tariq
6,821 조회수
Hi @JosafathB_Intel, I am facing the same problem.I am attaching my system info. Kindly guide me.
Thanks!
0 포인트
6,818 조회수
Sorry, attatched the old file previously.
Here is the new one. @JosafathB_Intel
0 포인트
LeonWaksman
수퍼 사용자
6,813 조회수
Hi @Muhammad_Ahsan_Tariq
1. You are not facing the same problem, since your system may be different (although you have the same laptop model).
2. From the attached SSU report I can't see that you have an Optane Memory installed in your laptop. In addition, you have a Toshiba 512 GB NVMe SSD and the NVMe SSD can't be and need not to be accelerated since this kind of drive is high performance drive. Only SATA HDD/SSD can be accelerated.
Leon
6,805 조회수
0 포인트
6,804 조회수
I changed my drive from AHCI to RAID mode and reinstalled my windows.
Should I revert it to AHCI mode? @LeonWaksman
0 포인트
LeonWaksman
수퍼 사용자
6,782 조회수
1. Yes that's right you should change your SATA mode back to AHCI:
2. In order to change SATA Mode without destroying Windows boot, Windows must be set to SAFE Boot Mode. While in Windows, press Windows key + r. Run msconfig .  Chose Boot tab and enable Safe boot. Reboot your system.
3. During system boot enter Bios.
4. Now you can change the SATA mode to AHCI. Save the setting  and boot into windows in SAFE mode. Disregard the warning you will see.
5. While in Windows, press Windows key + r. Run msconfig. Chose Boot tab and uncheck Safe boot
Leon
6,751 조회수
Did it. Thanks!
I also wanted to ask that when I move 4k content to my external Seagate hard drive 3.0 (same port in laptop),the transfer speed is pathetic,10 mb per sec.Is there any solution to it? @LeonWaksman
0 포인트
LeonWaksman
수퍼 사용자
6,746 조회수
There could be different reason for such low transfer speed. However, in most cases not the USB connection is the cause for that, but the write/read speed of your external drive. I'm using as an external drive WD Elements 3 GB drive and the transfer speed is about 100 MB/s
Leon
6,737 조회수
0 포인트
응답
