Intel® Optane™ Memory
1392 Discussions
Dual Boot drive with an Optane enabled secondary drive
ERoma2
Hey,
I currently have a setup with Windows 10 on a SSD as my system drive and an Optane accelerated HDD for media (games, programmes, etc). I am planning to install Ubuntu on the SSD (don't need to be able to connect to the HDD). I presume this should work without any problems?
Hi eugerome,
Thank you for posting in the Intel® communities.
As you mentioned, this setup should theoretically work as the secondary drive would be the one paired with the Intel® Optane™ Memory and they two would be linked to the Windows* partition in your primary drive, which means the Ubuntu* partition would be invisible for them. However, I cannot tell you if this setup will indeed work as this configuration is not validated or tested. Actually, this is a not supported configuration and the results are unknown.
Having said this, you can still try it, but it's up to you as we don't recommend to set the Intel® Optane™ Memory in this environment.
Have a nice day.
Diego V.
