Intel® Optane™ Memory
H10 + M10/HDD in one System?
EWese
Hello all
I would like to know, whether or not it is possible, to implement 2 Optane modules in one System for two different drives.
I am using an H10 512+32 GB as my boot drive and would like to hook up a 16 GB M10 to my HDD.
Unfotunately, I can't seem to find a definitive answer anywhere.
thanks in advance and stay healthy!
regards
n_scott_pearson
As far as I know, you can only have one Optane module in use in a system. If you have the H10, then you shouldn't have the M10.
EWese
I see, guess I didn't quite get the intention behind that whole thing then. Would it rather make sense to pair the optane module of the H10 with the SSD or rather HDD? Does it make any difference on daily use to unhinge the optane module from my boot drive? It certanly would improve the HDD, since that what it's made for am I right?
n_scott_pearson
No, the Optane memory in the SSD is there to accelerate the overall performance of the SSD. Honestly, introducing the H10 SSDs without the ability to use the caching capability across multiple of these drives and/or simultaneously allowing a M10 module to be used, makes absolutely no sense to me - and I originally hoped that I was wrong about this, but it is what it is...
Just a side comment: In my experience, using a Optane module to accelerate a (secondary) data HDD rarely improves performance by very much anyway. This technology is just not that effective in cases where the HDD contains a lot of rarely-accessed data files (pictures, etc.). It could be (more) effective if you had the larger M10 module and (thus) support for folder pinning. This feature helps a lot in, for example, cases where a game is installed on a HDD; just pin the game's folder.
LeonWaksman
The other solution is to installing a modern NVMe SSD instead of H10 512+32 GB in the first M.2. On this SSD you can install Windows 10 and other programs. In the second M.2 slot you can install M series Optane Memory Module to accelerated your data HDD.
Leon
EWese
well gee, what a bummer. thank you for your insightful replies.
I'll probably revert to SATA SSDs for this use then and ditch the HDD since i can't really be bothered to reinstall windows and all the other software on that drive.
stay healthy :)
