Intel® Optane™ Memory
1391 Discussions
HDD not shown up in Device Manager or Disk Management but recognised by Intel Optane Memory
fishfis
My HDD suddenly disconnected and dissappeared from Device Manager. But for some reasons i can still look it up in the Intel Memory and Storage Management. Any ideas what problem have i run into ?
n_scott_pearson
What you need to do it mark the drive as not being used for RAID or Optane. There could be a way to do this within the OMSM all; I am not sure. I usually do this in the Intel RST BIOS Support.
n_scott_pearson
What do you believe your system configuration actually is? This HDD is marked locked/offline; that's why you cannot see it in DM. It is also marked as being an array member, which would seem to indicate that the drive is considered part of a RAID array???
fishfis
I'm not really awared of my system configurations as the drive ran just fine until when i turned on my laptop without plugging in the AC adapter.  Why does the Intel Management app say that the HDD is locked ? Is it some sort of Security Freeze Lock or something ?
n_scott_pearson
