Intel® Optane™ Memory
1391 Discussions
How a backup image of my drive?
DPatt14
I've used Acronis backup for the past 10 years. But it cannot detect my Intel Optane PCIE drive. It shows all of my other drives. But for some reason cannot detect it.
Do you provide imaging software that works with the PCEI Optane or do you know of any third-party software companies that make one that is compatible with the Intel Optane PCIE?
LeonWaksman
  1. To make backup of your drive, disable Optane memory ennoblement first.
  2. Making backup on non accelerated drive, will protect your system in case of Optane memory fail or you HDD failure.
  3. You can not backup Optane memory.
  4. After performing backup, re enable Optane again.
Leon
LeonWaksman
Leon
DPatt14
Leon, I was able to perform a backup by creating a community made Acronis Boot Disk that uses Windows PE as a base. I had to preload the drivers into this. Then voilia. Perfect uncompresses images of my octane pcie. Now when my kids break something he my or get a virus I can reimage in 2 minutes flat! Life is beautiful.
