Intel® Optane™ Memory
Intel Optane Error
Calvin
I recently installed the intel optane memory application as I realized it wasn't being utilized by my PC. I keep trying to enable intel optane memory through the app but everytime I get error code 0xA0010055. I allocated memory for the intel optane memory, but even that didn't work. I am confused on what to do because I'd love to utilize it.
AlHill
Do you even have an Optane memory module installed?  Which module?
Does your system support Optane?
Did you create a partition at the end of your HDD?
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
LeonWaksman
Hi @Calvin
Follow Intel instructions to create 5MB unallocated space in the end of your HDD. Then try to enable Optane again.
Leon
