Intel® Optane™ Memory
Annonces
1386 Discussions
Intel Optane Memory 16 GB INACCESSIBLE_BOOT_DEVICE
Fer1
Débutant
24 684 Visites
Hi, I think I have a problem with my Intel Optane Memory.
I have a Lenovo Ideapad 330. While I´m using the laptop it show the blue screen with the error INACCESSIBLE_BOOT_DEVICE.
It doesnt happen when its starting, it happens while im using the computer.
I disable the memory and so far is working fine, but obviously I want to use it. I dont think its hardware beacause it has a year old. Buy it wasnt mino so I dont know how it was installed, at the beggining it all worked ok.
Do you recomend a clean start of windows and all the drivers? Is there anything I cuould run to detect if its a software problem? Can it be only a problem in the configuration of the Intel Memory?
Thanks everyone.
Étiquettes (4)
0 Compliments
LeonWaksman
Super utilisateur
24 366 Visites
Hi @Fer2
Instead to reinstall Windows, you may try to repair Windows with an in place upgrade.
Doing so, Windows installation will be refreshed while all you data and programs are kept. Execute this process with Optane disabled. It will take more time, but it is more safe.
Leon
Voir la solution dans l'envoi d'origine
0 Compliments
24 Réponses
Fer2
Débutant
4 104 Visites
@JosafathB_Intel @LeonWaksman
Unfortunately it didn´t work. I did all like you said. I don´t know what else is left, the intel software says everything is ok. If it is disabled everything works fine, slow but works.
Thanks!!!
0 Compliments
JosafathB_Intel
Modérateur
4 092 Visites
Hello Fer2,
Thank you for your reply.
We are glad to hear that your system is working and that you are not experiencing the same BSOD or errors related to the boot process of your OS.
We understand that your system will be working slower due to the Optane not being used.
Please contact Lenovo* and request technical support assistance to return you BIOS and OS
configuration to the out of the box state and to reactivate your Optane acceleration.
In case that you experience a BSOD or other errors, the best course of action will be to take it to the Lenovo* support center in your area to check if the issue is due to a hardware malfunction.
We are going to follow up with you again next Thursday, the 10th of December 2020, if we do not receive an answer from you. Please let me know if you would like to schedule a different date for the follow-up.
We will be looking forward to your reply in case you need further assistance.
Josh B.
0 Compliments
JosafathB_Intel
Modérateur
4 082 Visites
Hello, Fer1.
Greetings from; Intel® Memory and Storage support.
We were reviewing your community thread, which is related to your Intel® Optane™ Memory M10 Series. We would like to know if you were able to contact your OEM.
We are going to follow up with you again next Tuesday, the 15th of December 2020, if we do not receive an answer from you. Please let me know if you would like to schedule a different date for the follow-up.
We will be looking forward to your reply.
Josh B.
0 Compliments
JosafathB_Intel
Modérateur
4 074 Visites
Hello, Fer1.
We were reviewing your community thread, which is related to your Intel® Optane™ Memory M10 Series, and we have not heard back from you in a while, so we will proceed to close this inquiry now.
If you need assistance with an Intel® product, please open a new thread.
Josh B.
0 Compliments
Répondre
