Intel® Optane™ Memory
1391 Discussions
Intel Optane for HP Probook 430 G5 Core i7 8th Gen
ANugr1
Hello mastaaa,
Please help me to install Intel Optane on my notebook.
When I install intel optane, it always comes out of "bios not compatible"
here I attach the SSU scan results.
Hi adhika.nugroho,
Thank you for posting in the Intel® communities.
I understand that you would like to install the Intel® Optane™ Memory in a notebook, but you are getting a BIOS not compatible message.
That message is typically because your BIOS is not Optane Ready or there is something wrong configured at BIOS level.
After checking the following site, I can see that your notebook should support the module. Actually, the module should come already enabled and working: https://store.hp.com/us/en/pdp/hp-probook-430-g5-notebook-pc-customizable-1lr32av-mb
Having said this, I highly recommend you to contact HP* for assistance in order to know how to setup the module in this particular system. Configuring the Intel® Optane™ Memory in a laptop/notebook is not the same as in a Desktop computer. Laptops usually come with special settings and features included by the manufacturer that we are not aware of, so before performing system changes is better to contact the manufacturer for assistance.
From the HP* site, I was able to find some instructions to setup the module so I recommend you to check them and see if you are able to configure the BIOS and set the module up. If you are not able to setup the module with the HP* instructions, it's recommendable to contact them directly about this as they are the ones that can help you with the BIOS configuration and the module setup in their laptop models: https://support.hp.com/hk-en/document/c05591811
I hope you find this information useful. If there is something else I can help you with, feel free to ask.
Have a nice day.
Diego V.
Hi adhika.nugroho,
I'm just wondering if you contacted HP* for assistance on this, and if you were able to setup the module.
Diego V.
