Intel® Optane™ Memory
Intel Optane memory
Prithvi
I am not able to install intel Optane memory in my hp laptop i am getting error message how to solve
LeonWaksman
Hi @Prithvi
I would not advise to install Optane Memory, since it is an discontinued product. If you have free M.2 PCIe slot, buy an NVMe SSD and install it instead. You will have much better performance on your laptop.
However, if you insist to use Optane Memory,  in order to get better information about your system, please download the Intel System Support Utility (SSU). Run the SSU scan (check "Everything") and save the results. The .txt file with the results please attach to your post.
In addition, please give the P/N of the Optane memory you intend to use and the current SATA Mode in BIOS (the SATA mode in BIOS can be: AHCI, RAID or Intel RST Premium with Optane)?
Leon
Yogaeasvaran
Greetings,
Thank you for contacting Intel Customer Support.
We acknowledged your issue with Intel Optane Memory.
In order to isolate further, we would like to request SSU logs as you may follow the guide below link given:
Help Guide for the Intel® System Support Utility
Ryo
Yogaeasvaran
Greetings,
Regarding your case, we are following up to find out 2nd time if you were able to complete the actions, we previously recommended.
Please reply to this thread to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Yogaeasvaran
Yogaeasvaran
Greetings,
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Yogaeasvaran
