Intel® Optane™ Memory
1403 Discussions
Major Problem optane Accelerated HDD inacessable
AWoo1
fresh install of Windows 10 pro 64bit, downloaded & installed Intel® Optane™ Memory User Interface and Driver for System Acceleration Version: 16.5.1.1030,
setup the software correctly it restarted twice, everything was working properly last night, now I start my computer and D: drive is not showing in my computer
got to disk management to try to remap drive, can't do anything (most of the options are greyed out) and the HDD partitioning is all changed (it's an 8tb drive).
the files on the drive are completely inaccessible to windows, I can't even repartition it with disk management
attached screenshot shows disk management "Disk 0" was the accelerated drive
edit: I've solved to issue it was a corrupted GPT Table
Hello wooby6.
Thank you for contacting Intel Technical Support.
We are glad to hear you were able to resolve the issue you were experiencing and we would like to know if you need further assistance or if we can close this case?
Important note: Should further assistance or clarification be required, we will greatly appreciate if you reply to this post instead of writing a new one unless your inquiry is completely unrelated. This way we will prevent generating a duplicate post and we will not lose the train of thought.
We will be looking forward to your reply.
Josh B.
Under Contract to Intel Corporation
