Intel® Optane™ Memory
Memoria ram
Quinito
Buenas tengo este ordenador victus by hp 15l gaming desktop TG02-0xxx le meti 32g de ram y tengo la velocidad a 2133 MHZ ME GUSTARIA SUBIRLA A 3200 ,pero no me deja configurar a 3200 MHZ que es lo que tengo en la ram
AlHill
Contact HP for support of their device, memory, and BIOS.
AlHill
BrusC_Intel
Hello, Quinito.
Por favor tome en cuenta que soporte por la comunidad se da unicamente en ingles y hemos usado el traductor para proporiconar esta respuesta.
Thank you for posting on the Intel Community Support forums.
In this particular case, as AlHill mentioned, it is necessary for you to contact the system manufacturer (HP) for assistance, as they can confirm if this is possible or not and also provide you with instructions on how to do it.
The thread will be closed right now, and it will no longer be monitored by Intel support, but if you require any type of assistance from Intel in the future, just open a new thread, or contact us using any of the available support methods:
- https://www.intel.com/content/www/us/en/support/contact-intel.html
Bruce C.
