Intel® Optane™ Memory
1396 Discussions
NO PUEDO INSTALAR PROGRAMA MEMORY OPTANE
Er3santana
OPTANE.jpgTENGO ESTE PROBLEMA, SI ALGUIEN LE HA PASADO LO MISMO Y LO HA RESUELTO HAGAMELO SABER, O SI ALGUIEN SABE COMO Y POR QUE NO PUEDO INSTALAR EL PROGRAMA, GRACIAS
BrusC_Intel
Hello, @Er3santana.
Thank you for contacting the Intel Community Support.
I received your ticket regarding this error message during the Optane Memory setup process, I will be glad to assist you.
Please keep in mind that community support is provided in English only and the use of the translator may be required.
Have you tried installing the "Intel Optane Memory and Storage Management" from the Microsoft Store?
- Microsoft download page: https://www.microsoft.com/en-us/p/intel-optane-memory-and-storage-management/9mzng5hzwz1t
I would also like to know if you can provide us a full system report using the Intel SSU:
- Download: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Guide: https://www.intel.com/content/www/us/en/support/articles/000008563/software/software-applications.html
Bruce C.
A Contingent Worker at Intel
BrusC_Intel
Hello, @Er3santana.
I wanted to follow up on your ticket to check if you require further assistance.
I previously shared the possibility of installing the "Intel Optane Memory and Storage Management" from the Microsoft Store and also requested the system report to get a clear picture of your system configuration.
If you tested this recommendation or anything different and the ticket can be closed, please let me know.
Bruce C.
BrusC_Intel
Hello, @Er3santana.
This message is to follow up on your thread regarding Intel Optane Memory.
The thread will be closed for now as there has been no confirmation, please open a new thread if further assistance is required because this one will no longer be monitored. You may also contact us via one of the other support methods found in the following link: https://www.intel.com/content/www/us/en/support/contact-support.html
If you require any type of assistance from Intel in the future, you can always contact us back.
Bruce C.
