Intel® Optane™ Memory
1391 Discussions
No compatible disks for intel optane memory
Him
i recently build this new computer and such but i had an issue with windows 10. So i had to disconnect my hard drive (before this optane had been working properly). When i reconnected it i had received the what is written above, and i was wondering if resetting optane would work and how to do it
DiegoV_Intel
Hi Him,
Thank you for posting in the Intel® communities.
If you disconnected the drive (and re-installed the OS) without disabling the module from the application first, then it is most likely that you get that message. The module may still have the data from the previous system setup, and that’s preventing you from configuring it again.
As you mentioned, you can reset the module. This process is done from BIOS. You would have to navigate in the BIOS menu and search for the Intel® Rapid Storage Technology option. You should see your drives and the Intel® Optane™ Memory listed there. You can reset the module there is the BIOS has the option included (the option is usually named as "Reset-to-non-Optane"). I cannot give you more details on the specific location of this option because this depends on the BIOS itself which vary from system to system.
You can also try to clean the module’s data from Windows* following these steps:
  1. Open the Command Prompt as Administrator.
  2. Run the command diskpart.
  3. Run the command list disk to display all your drives in the system, including the Intel® Optane™ Memory. Take note of the ID number associated to the module.
  4. Run the command select disk <ID>. Use the ID for the Intel® Optane™ Memory.
  5. Run the command clean all to start the cleaning process. Make sure you selected the Intel® Optane™ Memory because this process will delete all data in the drive.
Once the process is complete, you can try to set it up again.
I hope you find this information useful.
Have a nice day.
Diego V.
Under Contract to Intel Corporation
DiegoV_Intel
Hi Him,
Have a nice day.
Diego V.
DiegoV_Intel
Hi Him,
Just wanted to confirm if the suggestion I shared with you helped you to recover the module.
Diego V.
