Intel® Optane™ Memory
1396 Discussions
Optane error code encountered which isn't in the support pages
CBugg
HI, I have experienced a problem installing Optane. When I run the setup program I receive the error code. 0xA0000001. This is not covered on any of the support pages I have been able to get into. According to HP I have an Optane enabled machine. I had hoped it would be a simple instal process but now realise it isn't. Frustrated........
Now all sorted after uninstalling and reinstalling software another time....
Message was edited by: Colin Bugg
LMila1
I have the same problem...
Hello LucasMilanese,
As reported by @ColB74, this issue may be resolved by reinstalling the Optane™ Memory Software. In previous instances, we've also been able to fix the problem with a low-level format: /thread/116281 Optane issues - error.
If none of this helps, please provide us the following:
1. https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility Intel® System Support Utility report, please select the option to scan "everything," then save the file to a known location.
2. A screenshot from your Disk Management console (diskmgmt.msc).
Carlos A.
Hello ColB74,
We have not heard back from you in a while. Has your issue also been resolved?
Carlos A.
Hello ColB74,
We understand you were receiving generic error code 0xA0000001 while trying to enable system accelerationg with Optane™ Memory. The error was resolved after reinstalling the software.
Thank you for updating us with your resolution.
If you need any further assistance, please let us know.
Carlos A.
