Intel® Optane™ Memory
1403 Discussions
Optane memory software install issue (partition cannot be resized)
ILast
I'm attempting to install the software on Windows 10 64x system but it states
'The last partition on your system drive cannot be resized, which is required to enable Intel Optane memory.'
Im guessing there is a partition somewhere that i need to unlock or something but i honestly have no idea what i am doing or how to fix this.
Any help?
Attached intel log file and dxdiag.
Hello Ianlast,
This error occurs when there is an unmovable recovery partition at the end of your current drive. Since active recovery partitions are protected by Windows* and cannot be moved nor resized, Intel® Optane™ will be unable to write it's required metadata information at the end of your disk.
Ideally, you should try to move the recovery partition 5MB away from the end of your drive. If this is not possible, you would need to consider deleting the recovery partition altogether and creating a recovery disk in it's place.
While we don't provide support for this action directly, the following article may help:
- http://Geek. https//www.howtogeek.com/139710/remove-your-pc%E2%80%99s-recovery-partition-and-take-control-of-your-hdd/ Remove Your PC's Recovery Partition and Take Control of Your Hard Drive - by How-To Geek*.
- https://support.microsoft.com/en-us/instantanswers/3a747883-b706-43a5-a286-9e98f886d490/create-a-recovery-drive Create a recovery drive - Microsoft* support.
On a personal note, in the past I've had great success performing this type of operations using http://www.partition-tool.com/ EaseUS Partition Master*.
NOTE: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here. You should always make sure to back up any important data before troubleshooting your storage devices.
Feel free to let us know if you have any remaining questions or doubts.
Carlos A.
Kkoko
Disk 0 is definitely optane, i did all the resizing with an other software and removed recovery with it, i play with it nicely allocating, shrinking, resizing no problem , but my question is why your optane doesn't show up like mine, is it something in the bios? Did you set up raid?
Kkoko
I'll try to remove the chip and see how it goes
Kkoko
Time here is 7:06 am, had hard time with this new system
RHOWA2
Yeah that is where I had the issue.
Just remove the memory chip
reset your bios SATA back to the original setting
Disable csm
Disable port remapping
boot to windows
install optane program
reboot to windows let it load but do nothing but
reboot to bios after windows has completed loading
I do not know if your mother board auto switched to optane if not in the sata settings check if not change to rst or optane whichever it list
disable CSM
reinstall chip
reboot
run the optane program
Some more errors will show up exit program
reboot
enable m.2 mapping
Enable CSM
reboot to windows
run program again
Kkoko
Thanks mate, I'll do that after i wake up and give you updates, really appreciate your help
RHOWA2
Lol
this was very trying for me too
FYI
I also learned about how to use the recovery USB after all this
tested it would not boot to recovery window
Had to change CSM to AUTO, only then would it boot to the recovery USB drive.
Once I know that switched CSM to disable
RHOWA2
here is what mine looks like now disregard the passport its a external backup drive
!!Note that in the disk management screenshot, that there is no unallocated space showing, it only shows up in easeUS there should be no unallocated space showing up on your disk management screen.
thats why it should be absorbed into drive C completely let Optane do the allocation.
Kkoko
That's problem and it's so confusing, if i absorb the 50mb, when i try to install optane it says it can't resize it for me, how can i create that unallocated space and it stays hidden? I'm using mini tool partition and easeus too
Kkoko
removed the chip installed software still have the same problem, i still don't know why my chip still show up in disk manager !
RHOWA2
Just so I am clear in the above image the optane chip is no longer installed?
If so then it is most likely not the the optane chip.
All I can think of is to use the merge option by right clicking on C: and try to merge Disk 0 with it.
But before you do the merge can you post a screen shot of the merge window (full screen)
Kkoko
In the above screenshot the optane is disk 0 so it's installed
RHOWA2
Okay then since the optane been partitioned for some reason
Using EaseUS Highlight disk 0 (GPT) right mouse click delete all partitions.
screen shot before and after please
Kkoko
Unfortunately I'm working night shift at the moment, will be home around 6am
Kkoko
I'll ring my wife and see if i can do something by TeamViewer, but I'm sure she's illiterate when it comes to computers lol
RHOWA2
Okay I will be away from my computer when you get home which my time will be 4:00 PM CST I should be back to my computer about that time and will look at your screen shots and reply with some more solutions.
My my thinking is that the optane partitions should deleted
run EaseUS highlight disk 0 delete all partitions click apply (let EaseUS finish)
power down
remove chip from the motherboard.
boot to bios (SATA settings should not be be set to raid optane)
with optane chip still removed from the motherboard
run EaseUS again then it should show disk 1 to now be disk 0.
at that point I would think that disk 0 will need to be resized by highlighting C: and increase the unallocated space after to 5mb click apply
After EaseUS is done reboot again run EaseUS again check to see if there is 5 mb unallocated on C: after
Still with no optane chip installed
Run optane EXE again (there will still be some error notes) but hopefully it will not say unsupported system drive.
if that happens then power down install chip
power up boot to bios change SATA setting to the intel optane or rst which ever your bios shows.
exit save changes, boot to windows run optane exe again
Kkoko
Thanks mate I'll give it a try, my bios changes auto to rst, i don't know if it's possible to merge optane with my hdd, have you tried it before?
RHOWA2
After removing the chip make sure the auto RST is set back to normal manually do so if needed.
I would not recommend merging the chip.
Optane exe will do that as needed
after everything is done and optane is running properly the drive properties should look like this
RHOWA2
which M_2 slot have you been using for the Optane Chip?
and is there a wireless M_2 Chip installed on your MB?
Kkoko
I had it installed in number 2 before, but today when i tried what you told me i put in number one next cpu, I've searched everywhere and couldn't find an explanation why it's showing up as storage
Kkoko
One more thing i still don't know how to create that unallocated space and it stays hidden and doesn't show up in disk manager
RHOWA2
Yeah disc manager will not show that
but you will see it in EaseUS
here is my screenshot showing the move resize option
but do this after the optane partitions have been deleted and chip removed from MB
